Greetings,
Is there a way to allow the declaration of an atom in the data file such that it takes up multiple lines?
Greetings,
Greetings,
not without changes to the parser. since that one is already quite
complex, i would recommend against it.
Is there a more elegant way to input dozens of properties to a single atom style entity that doesn’t require changing the parser or just having very long lines in the input file? I noticed changing the parser in read_data is what the body style ended up doing.
style entity that doesn't require changing the parser or just having very
how about writing a little
python/perl/tcl/c/c++/fortran/java/lisp/whatever program, that takes
whatever is a convenient input format for you and outputs a data file?
