While writing a dcd file using LAMMPS is it possible to view it using VMD before the entire simulation has been completed…??
This feature is there in NAMD but not directly possible using LAMMPS. Is there a way around this…??
before the entire simulation has been completed..??This feature is there in NAMD but not directly possible using LAMMPS. Is
there a way around this..??
i don't see a reason why this should not be possible outside of a
scenario where you would be running both LAMMPS and VMD on a windows
machine.
the windwos OS is the only environment that i know where you cannot
read a file that has been opened for writing by a different process.
