dcd/xtc writing limited to 2^31 timesteps?
I noticed that I have no problems running more than 2ˆ31 timesteps when writing to text dump files.
However, writing to binary files like dcd and xtc, lammps exits when hitting 2^31 timesteps with the error
ERROR: Too big a timestep for dump dcd (dump.dcd.cpp:129)
Is this a bug in lammps, a general restriction of dcd files, or some other problem?
I noticed that I can manually write dcd files that contain timesteps larger than 2^31, for example using MDAnalysis.
I am running a lammps build from 9 Nov 2011 on linux AMD 64.
the field in the dcd file that contains the timestep
number is a signed 32-bit integer, so you cannot
write larger time step numbers to the dcd file.
just use reset_timestep to keep the time step
number within 32-bits if you want to use dcd
or xtc format files.
but do they contain the correct time step number?
most likely that number is wrapped around or else
the format would not be correct.
