Hello Lammps Users,
I am new to lammps. I would like to know whether there is a way to define molecules (for fixes like gcmc which use only molecule template) from the data file created from read_data command.
Thanking you in advance.
Regards,
Birva Patel
Hello Lammps Users,
no.
the syntax is similar, but not the same, and the molecule command needs to
know different information and have organized differently, that what
read_data requires.
since fix gcmc makes the most sense for atoms or rather small molecules, it
should not be a big burden to write a molecule file directly in a text
editor.
the bigger challenge usually is to set up a meaningful simulation in the
first place.
