This question is mainly tied to simulation efficiency. When using a typed force field like OPLS, there are often atom types where multiple types of bonds/angles/etc. share the same bond/angle/etc. parameters. In these cases, I was wondering if there is an appreciable performance penalty to specifying multiple bond/angle/etc. types with the same parameters.
The main reason I was considering doing this was to make the input decks more self-documenting, where I could use comments to clearly indicate, e.g., that a given bond type was for a specific moiety in the molecule. However, this requires repeating essentially the same bond_coeff command multiple times, just with a different value for the bond type. This also allows for some flexibility in selecting those specific bond/angle/etc. types for post analysis, using things like Ovito.
So would I notice much of a performance hit having these extra interaction types? Do people have suggestions for better was to handle these types of situations?
