Steve,
I have a ‘behaviour’ comment rather than a bug report.
I am creating an odd shaped region of atoms (outer skin of a Berkovich indenter) by creating two sets of intersecting planes.
The final structure is carved from a large block using the delete_atoms command. (I tried just filling the region, but lammps complained. My method worked, so I went with it). However, when I went from the test case to the full setup, I got the error “
Initially I couldn’t see where I was, or wasn’t setting IDs. So I looked in the code, and found the issue was not the delete_atoms part, but in the create_atoms.cpp, line 238 there is a test. If the number of atoms exceeds some hardcoded value it does not set IDs (Atom->tag_enable = 0).
I know it’s a big number of atoms, but since I wanted to delete most of them, it did not seem an issue. I don’t know what other commands would look for IDs, but can you put a warning there, so others don’t get confused about the issue.
Cheers
Nigel
