I constructed a 2D materials model containing the elements of B, N, and C. I used a BNC tersoff potential to describe the in-plane interaction among B-N-C. But this potential shows a poor performance in describing interlayer interaction between the neighboring layers , such as BN layer and Carbon layers, and two BN layers.
So, to address this issue, I used a morse potential for a better modelling the weak interaction between BN and carbon layers. And also found a LJ parameter to deal with the interlayer interaction between two BN layers. (more detailed setting can be found below)
The simulation can be proceed correctly when only tersoff and morse potentials are used. But, once the LJ parameter that used to describe the layer interaction of BN. The simulation is stopped by a error of “Segmentation fault (core dumped)”.
------------- Initialization
dimension 2
atom_style atomic
box tilt large
------------- System definition
read_data BN_Gra-27.6nm-3l-AP3-bulk4.data
------------- Simulation settings
pair_style hybrid/overlay tersoff morse 4 lj/cut 4
#pair_style hybrid/overlay tersoff lj/cut 4
pair_coeff * * tersoff BNC.tersoff B N C
pair_coeff 1 3 morse 0.0029 2.08 3.56
pair_coeff 2 3 morse 0.0083 2.54 3.54
pair_coeff 1 2 lj/cut 0.004 3.212
neigh_modify every 1 delay 10 check yes
write_dump all xyz opt.xyz modify element B N C
dump mydmp all atom 1000 dump.lammpstrj
region bulk block 0.0 276.115 0.0 239.1213922167 1.7 5.3
group bulk region bulk
------------- Run
thermo 5
#timestep 0.005
minimize 1.0e-5 1.0e-6 1000 10000
write_data BN_Gra-27.6nm-3l-AP3-bulk4-opt.data
------------- MD
fix 1 all nvt temp 50.0 50.0 5
#fix mynve all nve
#fix mylgv all langevin 300 300 0.1 10000
fix 3 bulk enforce2d
thermo 1000
run 500000
write_data BN_Gra-27.6nm-3l-AP3-bulk4-final.data
dump 1 all movie 1000 movie.avi type type
write_dump all xyz all.xyz modify element B N C
Can someone give me some guidance about how the error occurs and how to solve this issue?
Thanks in advance.
Guo
