I am encountering this strange problem. When I create the structure and minimize it, working temp is 0 but if I input the structure and it reads the coordinates, I am getting 600K as a temperature for minimization. Can you please let me know the cause of this and how to get rid of it?
Here are two input files:
the temperature is computed from whatever kinetic energy,
i.e. velocities and masses, your atoms have.
you can use the velocity command to change it.
however, the temperature should be _no_ consequence for
minimization. a minimization always corresponds to 0K.
Axel is correct - the temperature is ignored
during minimization. Does your data
file have velocities defined? That would
explain why you get a T of 600K after
you read it in.
