Different velocities by changing thermostating way.
Dear LAMMPS users:
I am running two simulations of pressure-driven water flow (spce) inside a CNT. Both are at the same temperature 298K and both are under the same pressure gradient P1 by using fix addforce in the z-direction. Both tests are basically the same, the only thing that I changed is the way of thermostating.
In test1 I used 2 thermostats one for the CNT and another for the water; in this case I got an average velocity of 250 m/s.
In test2 I used only one thermostat for the whole system, and I got an average velocity of 400 m/s.
In both cases I used fix nvt and temp/profile for removing the z-direction degree of freedom for the temperature saw by the thermostat. I am using a 20 timesteps Tdamp. Each timestep is fs (real units).
I expected to get the same velocity in both cases, what am I misunderstanding or what am I doing wrong?
I am using Tersoff for the CNT and LJ for interactions water-CNT. I am using a May15-2015 version.
Thank you very much for your help.
Jose Cobena
Mork Family Department, USC.
Dear LAMMPS users:
thermostating.
i would expect to see *different* temperature profiles for the water in the
two cases and thus the biasing would be different and consequently you
should get different results.
axel.‚Äč
