Dear users and developers:
I would like to simulate the diffusion coefficient of n-pentane at 300K and 1 atm by TraPPE-UA force field with MSD method, but the value I got is higher than the literature (the literature mentioned is 6.14e-9m2/s of pure n-pentane in the same condition, what I got is around 7.4e-9m2/s). Then I trid to repeat the processes given in the literature but stilll got the wrong value. When I saw back in my log file, I found the box shrink when I apply NPT ensemble to control the press in 1 atm, and I got a higher density than the literature (the density in literature is 620.19kg/m3, what I got is about 630kg/m3). Here is my input script and a part of data file:
############input script:
units real
atom_style full
bond_style harmonic
angle_style harmonic
dihedral_style opls
read_data fprintf.out
pair_style lj/cut 14.0
pair_coeff 1 1 0.1947 3.75 #epsilon,sigma for (CH3-C5)-(CH3-C5)
pair_coeff 1 2 0.1334 3.85 #epsilon sigma for (CH3-C5)-(CH2-C5)
pair_coeff 2 2 0.09138 3.95 #epsilon sigma for (CH2-C5)-(CH2-C5)
pair_modify tail yes
bond_coeff 1 95.8052 1.54
angle_coeff 1 62.050 114.0
dihedral_coeff 1 0.00 1.4099 -0.27068 3.1425
neighbor 2.0 bin
#structure optimization
replicate 2 2 2
thermo 100
thermo_style custom step temp etotal press vol
minimize 1.0e-4 1.0e-6 10000 10000
write_restart restart.%.*
#NVT ensemble: up to 700k
timestep 0.1
fix 1 all nvt temp 0.1 700.0 10.0
thermo 5000
thermo_style custom step temp ke pe etotal press vol
run 1000000
unfix 1
keep system in 700k for a while
fix 2 all nvt temp 700.0 700.0 10.0
thermo 5000
run 2000000
unfix 2
down the system 500k
fix 3 all nvt temp 700.0 500.0 10.0
thermo 5000
run 3000000
unfix 3
#down the system 300k
fix 4 all nvt temp 500.0 300.0 10.0
thermo 5000
run 5000000
unfix 4
#keep system in 300k for a while
fix 5 all nvt temp 300.0 300.0 10.0
thermo 5000
run 5000000
unfix 5
#NPT
timestep 1.0
thermo 5000
fix presscontrol all npt temp 300.0 300.0 100.0 iso 1.0 1.0 1000.0
run 5000000
unfix presscontrol
begin control temperature in 300k for 2ns
reset_timestep 0
fix 6 all nvt temp 300.0 300.0 100.0
compute 1 all msd com yes
variable msdC5 equal c_1[4]/6/(step*dt+1.0e-6) #1.0e-6 is for denominator is not zero
thermo 5000
thermo_style custom step temp ke pe etotal press vol c_1[4] v_msdC5
run 2000000
unfix 6
#nve for 5ns
reset_timestep 0
fix 7 all nve
compute 2 all msd com yes
variable msdC52 equal c_2[4]/6/(step*dt+1.0e-6) #1.0e-6 is for denominator is not zero
thermo 5000
thermo_style custom step temp ke pe etotal press vol c_2[4] v_msdC52
run 5000000
unfix 7
EMD for 5ns
reset_timestep 0
fix emd1 all nve
compute 3 all msd com yes
variable msdC53 equal c_3[4]/6/(step*dt+1.0e-6) #1.0e-6 is for denominator is not zero
thermo 5000
thermo_style custom step temp ke pe etotal press vol c_3[4] v_msdC53
run 5000000
#########data file
625 atoms
500 bonds
375 angles
250 dihedrals
2 atom types
1 bond types
1 angle types
1 dihedral types
0.000000 28.921897 xlo xhi
0.000000 28.921897 ylo yhi
0.000000 28.921897 zlo zhi
Masses
1 15.033000
2 14.028000
Atoms
1 1 1 0.000000 0.030030 13.526048 4.639302
625 125 1 0.000000 5.860296 7.088066 9.130796
Bonds
1 1 1 2
500 1 624 625
Angles
1 1 1 2 3
375 1 623 624 625
Dihedrals
1 1 1 2 3 4
250 1 622 623 624 625
I have put the input script (in.C5), data file (fprint.out) and log file in the attachments, please check.
Did the density effect the coefficient a lot? Did I set something wrong in my input script so that I got higher values of density and diffusion coefficient? I have tried to run longer but it does not working well.
The literature is [Antoun S , Saghir M Z , Srinivasan S . An improved molecular dynamics algorithm to study thermodiffusion in binary hydrocarbon mixtures. J. Chem. Phys., 2018, 148 104507.]
Best wishes for you
Xiaoyu
fprintf.out (56.4 KB)
in.C5 (3.29 KB)
log.lammps (649 KB)
