Hello Users,
I’m trying to use pair_style lj/gromacs with a dihedral_style charmm but I’m getting the error:
Dihedral charmm is incompatible with Pair style
The force field uses those equations so I’m wondering if there is a work around?
Hello Users,
Hello Users,
I'm trying to use pair_style lj/gromacs with a dihedral_style charmm but I'm
getting the error:Dihedral charmm is incompatible with Pair style
The force field uses those equations so I'm wondering if there is a work
around?
it cannot do the *exact* equations, since charmm dihedrals
have a somewhat unusual way to do 1-4 exclusions.
a) you can use one of the lj/charmm pair styles instead of lj/gromacs
remember that 1-4 exclusions are "special" with this.
b) you can generate your own charmm/compat dihedral style,
by removing the code that is required for compatibility with
the lj/charmm pair styles.
c) you can use the table dihedral style.
