Dear All,
I used the following script to run the dna example but it only writes Carbon in the dna.lmp file. Could you please help me resolving this issue? The same problem exists in the peptide example. I need all atoms printed in my *.lmp file when I use:
dump dump2 all custom 10 dna.lmp element xu yu zu
dump_modify dump2 sort id
# lammps script
# initialization
units real
newton on off
atom_style full
# default lattice
lattice fcc 1
# pair_style
pair_style lj/charmm/coul/long 8 10 10
# angles
angle_style charmm
# bonds
bond_style harmonic
# dihedrals
dihedral_style charmm
# impropers
improper_style harmonic
# kspace
kspace_style pppm 0.0001
# read_data
read_data /Users/amirvahid/Documents/lammpsfe/examples/dna/dna/1ac7.data
# velocity
velocity all create 0 12345678 dist uniform
# processing
thermo 1
timestep 0.5
dump dump1 all atom 10 dump.xyz
# pre-run scriptlet begin
neigh_modify delay 2 every 1
pair_modify mix arithmetic
special_bonds charmm
fix 2 all shake 1e-6 500 0 m 1.0 a 93
# pre-run scriptlet end
fix nve1 all nve
run 1000
Thanks!
