The code displayed in the documentation for firetask tutorial https://pythonhosted.org/FireWorks/firetask_tutorial.html is different than what is in addition_task.py.
#!/usr/bin/env python
from fireworks.core.firework import FWAction, FiretaskBase
author = ‘Anubhav Jain’
copyright = ‘Copyright 2013, The Materials Project’
version = ‘0.1’
maintainer = ‘Anubhav Jain’
email = ‘a…@lbl.gov’
date = ‘Feb 17, 2013’
class AdditionTask(FiretaskBase):
_fw_name = “Addition Task”
def run_task(self, fw_spec):
input_array = fw_spec[‘input_array’]
m_sum = sum(input_array)
print(“The sum of {} is: {}”.format(input_array, m_sum))
return FWAction(stored_data={‘sum’: m_sum}, mod_spec=[{’_push’: {‘input_array’: m_sum}}])
Apologies if this is not the place to bring this up. Thanks! Hope to use this at JGI!
Hi Mario,
This is indeed the correct place - thanks for pointing out the inconsistency. We have fixed it and it’s pushed online.
Let us know if you have any questions during your investigation of using FireWorks at JGI.
Anubhav
version = ‘0.1’
email = ‘aj…@lbl.gov’
