on the documentation page for the Trackers,
https://pythonhosted.org/FireWorks/tracker_tutorial.html
the code snippet says that you should import Tracker by doing e.g.
from fireworks import Firework, Tracker, ScriptTask, TemplateWriterTask
This fails with an ImportError:
>>> from fireworks import Firework, Tracker, FWorker, Workflow
File "<stdin>", line 1, in <module>
ImportError: cannot import name Tracker
Doing
from fireworks.core.firework import Firework, Tracker, FWorker, Workflow
does work.
Is importing from fireworks.core.firework the recommended way of importing Fireworks classes?
Rasmus
Hi Rasmus,
Thanks for the question
You are correct about the import statement being wrong - one of the devs has just pushed a commit to Github so that the import works as intended. The change will also be reflected in the next PyPI release (probably Friday or so)
You can also import from fireworks.core.firework as you wrote.
Best
Anubhav
ยทยทยท
Doing
does work.
Rasmus
