Dear Sir,
I am trying to simulate gliding between hydroxylapatite and titanium oxide. I am using version of LAMMPS 24 Dec 2020 in workstation. Because I am newcomer, it is impossible to upload input file. I will provide my input information below.
Here is initial information of system.
boundary p p s
atom_style full
The atomic model includes 2650 atoms which are belonged to 7 types (1-Ca, 2-P, 3-O, 4-O, 5-H, 6-Ti, 7-O). Potential parameters are following:
pair_style hybrid/overlay lj/class2 9.6 coul/wolf 0.2 9.6 buck 12 lj/cut 6.0
pair_coeff 1 1 lj/class2 0.010403121 3.55
pair_coeff 1 2 lj/class2 0.010538514 4.15596616
pair_coeff 1 3 lj/class2 0.000119856 3.525443145
pair_coeff 1 4 lj/class2 0.000444298 3.685565322
pair_coeff 1 5 lj/class2 7.69584E-07 3.163151757
pair_coeff 2 2 lj/class2 0.010836584 4.5
pair_coeff 2 4 lj/class2 0.000401311 4.221196028
pair_coeff 2 5 lj/class2 6.94919E-07 4.009185222
pair_coeff 3 3 lj/class2 0.002384049 3.5
pair_coeff 3 4 lj/class2 0.001690174 3.665276256
pair_coeff 3 5 lj/class2 3.06057E-05 3.118640711
pair_coeff 4 4 lj/class2 0.003467707 3.8
pair_coeff 5 5 lj/class2 0.000563502 1.098
pair_coeff 6 7 buck 16957.7 0.194 12.593
pair_coeff 6 6 buck 31120.4 0.154 5.247
pair_coeff 7 7 buck 11782.8 0.234 30.222
pair_coeff 1 6 lj/cut 0.014018 3.296483
pair_coeff 2 6 lj/cut 0.013449 3.809286
pair_coeff 3 6 lj/cut 0.007655 3.357039
pair_coeff 4 6 lj/cut 0.007655 3.357039
pair_coeff 5 6 lj/cut 0.006566 30047523
pair_coeff 1 7 lj/cut 0.029760 3.451346
pair_coeff 2 7 lj/cut 0.029868 3.889502
pair_coeff 3 7 lj/cut 0.015000 3.500000
pair_coeff 4 7 lj/cut 0.015000 3.500000
pair_coeff 5 7 lj/cut 0.010959 3.263471
pair_coeff * * coul/wolf
In first stage of simulation, system is minimized using cg algorithm. Then, gliding process is performed with NVE ensemble method using following commands.
#MINIMIZE
minimize 1.0e-4 1.0e-6 100 1000
min_style cg
#GLIDING
reset_timestep 0
timestep 0.0001
velocity all create 300 12345 mom yes rot yes dist gaussian
#FIX_COMMANDS
fix 1 all nve
fix 2 1 addforce 0 0 -0.00261
fix 3 3 setforce 0 0 0
fix 4 all temp/rescale 1 300 300 0.02 1
fix 5 1 move linear 1 0 0
#THERMAL
thermo 1
thermo_style custom step lx ly lz pxx pyy pzz pxy pxz pyz pe ke etotal press vol density temp
run 1.0E7
In this stage, simulation just performed only 29 steps then error “Domain too large for neighbor bins” is reported like in this image.
Could you give me some instruction to solve this problem?
Thank you.
