Dear Lammps user.
What is the reason for the following error in the simulation? How can I solve this problem? I tried to increase the Skin value, but it did not work and the problem persists. Does anyone have a better solution for this problem?
Error: Domain too large for neighbor bins (… /nbin_standard.cpp:104)
The error message for this may be misleading, since it is usually caused by bad input and thus this is more a symptom that the cause and making the symptom go away does not remove the cause.
There is not enough information here to give any more specific suggestions.
Please have a look at the mailing list guidelines, which apply to the forum just as well, about how to ask and what information to provide.
https://lammps.org/guidelines.html
Thank you Mr. Professor for your reply.
Thanks for the link!
