Doubth with fix aveforce
I have a small doubt with how fix aveforce works. So basically I want to
impose an average force to all the atoms in a sliding wall in a certain
direction so I do:
fix set_pressure_fix_l lower_g aveforce NULL NULL \{required\_wall\_force\} fix set\_pressure\_fix\_u upper\_g aveforce NULL NULL (-v_required_wall_force)
Does the average computed at time t take into account the force added
in time step t-1? Or the average force is only calculated from the
interaction energy of the atoms and then the force is added every
timestep?
I guess the second statement is what is happening but wanted to make
sure.
Regards,
Eduardo
- MSc student at Imperial College London
direction so I do:
in time step t-1?
No.
timestep?
not quite sure what you mean by this.
fix aveforce does what it says it does: it averages the
(instantaneous) force in each selected dimension and optionally adds
an additional external term to it.
sure.
guessing is never a good idea for these kind of issues. if you want to
be certain, set up a (simple) test system and output all relevant
properties with fix aveforce turned off and on and see for yourself.
