Hi Axel,
I am giving the example file , where i am facing the problem.
i will also attach the files…
data file
LAMMPS DESCRIPTION
6 atoms
4 bonds
2 angles
2 atom types
1 bond types
1 angle types
-50.000000 50.000000 xlo xhi
-50.000000 50.000000 ylo yhi
-50.000000 50.000000 zlo zhi
Atoms
1 1 1 0.000000 -48.707913 -8.268376 -11.909736
2 1 2 0.000000 -49.602863 -8.257826 -12.355908
3 1 2 0.000000 -48.749200 -7.731221 -11.067194
4 2 1 0.000000 -0.054055 4.721854 26.485373
5 2 2 0.000000 0.447696 5.565017 26.678862
6 2 2 0.000000 -0.540202 4.427055 27.308096
Bonds
1 1 1 2
2 1 1 3
3 1 4 5
4 1 4 6
Angles
1 1 2 1 3
2 1 5 4 6
parameter file
pair_style hybrid/overlay lj/cut 15.0 hbond/dreiding/lj 4 4.0 5.0 90
pair_modify shift yes mix geometric
bond_style harmonic
angle_style harmonic
special_bonds dreiding
mass 1 15.9994
mass 2 1.0080
bond_coeff 1 350.00 0.98
angle_coeff 1 50.00 104.51
pair_coeff 1 1 lj/cut 0.215 3.127054
pair_coeff 2 2 lj/cut 0.000 2.138156
pair_coeff 1 1 hbond/dreiding/lj 2 i 9.0 2.75 4 5 90
Input file
units real
atom_style full
read_data data.water
include parm.water
neighbor 2 bin
timestep 0.5
run_style verlet
thermo_style multi
thermo 10
thermo_modify flush yes
dump 1 all custom 100 dump.minimize id mol type xu yu zu
dump_modify 1 flush yes
restart 1000 rA.rest rB.rest
minimize 1e-10 1e-10 100000 1000000
write_restart r.rest
thanks a lot…
karthik
data.water (1.12 KB)
parm.water (466 Bytes)
in.water (593 Bytes)
