You can define a variable and then output that in your dump file. Please refer to manual for manual for more details.
Arun
Arun
Thanks for reply.
But as temperature is not per-atom quantity rather a global parameter. Is it possible to dump temperature at every timestep the trajectories of atoms are dumped?
yes, just not in the same file.
You can output it with thermo output (to the log file).
You can use the fix ave/time command to output
it into its own file.
You can use the fix print command to output
yes. you can get all thermodynamic variables using ‘thermo time step’
Santo
