Dump file in Tecplot
Dear lammpsusers,
I would like to dump the trajectories of the atoms in the tecplot software.
The tecplot doesnt accepts the file as produced by Lammps . It needs to be
converted into ASCII format. How can we do this?
Dear lammpsusers,
LAMMPS dump files *are* in ASCII unless you explicitly request binary output.
however ASCII is just an encoding not a specific format.
to convert dump files for a specific software, you need to first learn
what specific format this software expects. then you have to write a
program that reads and parses the dump file and outputs it in the
desired format. if you write that program in python, you can get help
from the Pizza.py package as far as reading LAMMPS dumps are
concerned. as far as tecplot compatible output is concerned, you are
on your own.
