I could locate my dump file, though it says the system is equilibriated. Please help me with the same, if possible.
Yours sincerely,
Deep Patel
new2.txt (2.58 KB)
Yours sincerely,
Deep Patel
new2.txt (2.58 KB)
A small error in that code. Kindly shift the two commands of mini, i.e minimize and min_style after the two fix commands and then try fo run the code and revert me, if dump file is traced or not.
nobody can run this, because you didn’t provide the data file.
