dump image seg fault
Hi
I am trying to use the dump image command to produce an image of my simulation which just produces a segmentation fault.
Commenting out the dump image line the simulation runs fine.
- I am running the 8 Aug 2014 version of Lammps.
- It is compiled with jpeg libraries
- dump image works with some previous code, main difference is atom style (molecular vs template)
- I have removed the file extension from the dump image to output a PPM, still set faults
I am not sure what else to try. I suspect it might be something to do with the atom_style template.
Any help would be most appreciated.
Malcolm
data.Snowman (225 Bytes)
in.molecular (645 Bytes)
molecule.Snowman (213 Bytes)
there is logic in dump image to draw bonds for atom_style template,
but it’s new and there is probably a bug - I’ll take a look
