I have been trying to make the dump_modify
command to work for a specific group, but to no avail: error: dump modify element names do not match atom types
For example, the dump_modify
for the dump all ...
works, but gives an error for dump group-ID
. My input script:
# Simulation box
units real
atom_style full
# interactions/FF
bond_style harmonic
angle_style hybrid fourier cosine/periodic harmonic
dihedral_style harmonic
improper_style fourier
pair_style lj/cut/coul/long 12.5
pair_modify tail yes mix arithmetic
special_bonds lj 0.0 0.0 0.0
# Read data file
box tilt large
read_data ./config.data nocoeff
mass 1 63.546
mass 2 1.00794
mass 3 12.0107
mass 4 12.0107
mass 5 15.9994
mass 6 28.0855
mass 7 15.999
mass 8 15.0342
bond_coeff 1 185.539128 1.933501
angle_coeff 1 fourier 148.822143 0.343737 0.374972 0.281246
dihedral_coeff 1 1.250000 -1 2
pair_coeff 1 1 0.005000 3.113691
kspace_style ewald 1.0e-6
# Atom Groupings
group surrounding type 1:5
group diffuse type 6:8
set group diffuse charge 0.0
# Neighbour list
neighbor 2.0 bin
neigh_modify exclude molecule/inter diffuse
# Simulation
variable T equal 435
variable S equal 12345
velocity all create $T $S rot yes mom yes dist gaussian units box
run_style verlet
# Output system properties
thermo 1000
thermo_style custom step temp press etotal pe ke evdwl ecoul epair enthalpy vol cella cellb cellc cellalpha cellbeta cellgamma density
log thermo.dat
restart 2000000 rst
print "================================================="
print "------> EQUILIBRATION "
fix RIGID surrounding npt temp $T $T 100 tri 0.1 0.1 100
fix FLEX diffuse nvt temp $T $T 100
fix TETHER1 all momentum 1 linear 1 1 1 angular rescale
fix RECENTER surrounding recenter INIT INIT INIT units box
dump Surroundtraj surrounding xyz 50000 traj_surround_equil.xyz
# I get an error if the line below is included
dump_modify Surroundtraj element Cu H C C O
dump Trajectory all xyz 50000 traj_equil.xyz
dump_modify Trajectory element Cu H C C O Si N P
timestep 0.5
run 10000000
undump Trajectory
undump Surroundtraj
# script continues...
unfix TETHER1
unfix RECENTER
unfix RIGID
unfix FLEX
A snippet of the xyz
file generated without dump_modify Surroundtraj element Cu H C C O
is attached below. I can only see 5 numeric labels. Have I missed something here?
3402
Atoms. Timestep: 0
1 13.4497 4.03958 7.69237
1 9.28749 10.5696 7.64015
1 13.5566 8.45614 1.17331
2 15.4721 5.49815 7.8657
2 14.0039 4.80157 7.56856
2 11.705 9.91234 7.88983
2 10.2512 10.6481 7.96584
2 13.8437 9.39909 3.43218
2 14.1934 8.61301 1.98208
2 13.4263 4.96152 3.56898
2 10.1368 6.43971 7.85744
2 10.4397 9.71299 3.5803
3 12.6183 2.95618 5.17471
3 12.3512 3.19286 3.72225
3 11.4784 2.30699 3.06143
3 7.95067 8.01782 7.80334
3 8.00789 6.5294 7.99424
3 6.83866 5.77602 8.21823
3 10.7971 8.7643 0.972188
3 9.50653 9.24464 1.603
3 8.29532 9.13921 0.899805
3 8.219 10.2362 5.09561
3 8.30445 10.0613 3.58592
3 7.14178 9.89577 2.7711
3 10.6314 3.8592 8.07327
3 9.30202 4.42316 8.11626
3 8.06908 3.67155 8.21929
3 12.6369 5.86728 1.03065
3 12.3245 4.54189 1.65093
3 11.4044 3.62134 1.06921
3 12.7528 4.33574 3.0128
3 11.1022 2.45961 1.7099
4 10.1075 1.53064 1.19155
5 13.4547 3.45697 9.53733
3 9.22072 5.82593 7.94085
3 6.83761 4.36369 8.35793
4 5.63597 3.58182 7.99836
5 14.5206 5.5567 7.77201
3 9.45777 9.64427 2.95482
3 7.13365 9.25218 1.55168
4 5.94798 8.65727 1.03079
5 14.9401 2.83573 7.47443
4 4.63286 2.96356 7.72943
5 14.488 9.00435 2.85492
5 11.1721 10.6727 8.17272
5 13.0314 3.94123 5.82933
5 9.04976 8.68866 7.84735
5 11.8083 8.75821 1.71436
5 9.27929 10.4833 5.76115
5 11.6893 4.58086 7.99093
5 13.2923 6.70373 1.70441
5 8.81941 12.4303 7.54224
2 6.13482 10.3214 3.1293
5 8.67523 10.687 9.45257
4 9.19411 0.887162 0.774428
4 4.89587 8.28365 0.612362
5 15.0245 7.72356 0.200856
5 7.06014 10.0609 5.61268
5 13.6399 10.0724 0.286422
2 11.1292 1.44189 3.5378
1 19.5526 12.216 13.9782
3 20.8562 16.2039 13.5433
2 15.4406 13.0211 15.0749
2 18.3823 8.36314 15.2341
5 20.4283 8.50788 20.9221
2 18.5269 12.6526 11.7303
2 19.1484 11.9246 13.0819
3 20.468 14.8773 14.0719
3 22.5021 12.1764 14.0686
5 20.0067 13.9859 13.3213
5 18.0781 13.0751 14.8871
5 19.2861 10.7285 15.03
Thank you,
Jean
