Dump_nc command
Dear Lammps Users,
I have built lammps with USER-NC dump package .
A) I use following commands
compute p all pe/atom
compute dis all displace/atom
dump 1 all nc/mpiio 5000 traj.nc type x y z c_p c_dis[4]
I get the following error:
ERROR: 0 dimensions for ‘c_dis’. Not sure how to write this to the NetCDF trajectory file. (…/dump_nc_mpiio.cpp:439)
B)When I use the following commands :
compute te all temp
dump_modify 1 append yes at -1 global c_te
ERROR on proc 0: NetCDF failed with error ‘NetCDF: Variable not found’ (while accessing ‘c_te’) in line 337 of …/dump_nc_mpiio.cpp. (…/dump_nc_mpiio.cpp:1046)
Could someone give an insight to it?
Nikhil
Dear Lammps Users,
*ERROR: 0 dimensions for 'c_dis'. Not sure how to write this to the NetCDF
trajectory file. (../dump_nc_mpiio.cpp:439)*
​apparently, dump nc is missing support for per-atom arrays and selecting
per-atom vectors from them. this can be worked around with an atom-style
variable. ​e.g. like this:
variable dis atom c_dis[4]
dump
​1​
all nc 50 traj.nc type x y z c_p v_dis
compute te all temp
*ERROR on proc 0: NetCDF failed with error 'NetCDF: Variable not found'
(while accessing 'c_te') in line 337 of ../dump_nc_mpiio.cpp.
(../dump_nc_mpiio.cpp:1046)*
not sure if this is a bug, but the same kind of workaround helps here:
compute te all temp
variable te equal c_te
dump 1 all nc 5000 traj.nc type x y z
dump_modify 1 global v_te
​if you do not want to use these hacks or have more detailed questions, i
suggest you contact the developer of the USER-NC-DUMP package. email
address is in the README file.
axel.​
