dump particular type atom in subgroup
Dear Users,
I want to dump atoms in subgroup with particular type atom.I have not found ways to defined this by taking look at dump_modify command. Is Lammps support this type of output?
Like,I have four types of atoms in subgroup.type 1 2 3 4.However, i just want to dump type 2 in subgroup,is that possible?
dump 2 subgroup atom 50 dump.run.bin
Moreover,Could you please inform me how to setup command to reduce ahead of information in dump file.Like ITEM …information below:
ITEM: BOX BOUNDS xx yy zz
xlo xhi
ylo yhi
zlo zhi
Thank you very much for your help
Best Regards
Liyi
Dear Users,
​yes. just create a new group.​
of information in dump file.Like ITEM ....information below:
ITEM: BOX BOUNDS xx yy zzxlo xhiylo yhizlo zhi
​you cannot. write compressed or binary dump files, if you need to conserve
space. if that is not enough, then you are writing out data too frequently
for post-processing ​to make sense and it would be better to do analysis
during the run.
Thank you very much! Axel,it works now.
