Dear Lammps user,
In my input script I wrote following command:
dump dmpvtk all vtk 100 dump*.myforce.vtk id type vx fx
But I get the error:
ERROR: Invalid dump style (…/output.cpp:574)
also I did :
make yes-USER-VTK
make mpi
And also when I do “make yes-USER-VTK” it works, but the next command line give me:
make[1]: Verzeichnis „/home/mborreguero/Work/lammps-11Aug17/src/Obj_mpi“ wird betreten
…/…/lib/quip/Makefile.lammps:17: *** Environment or make variable QUIP_ROOT must be set… Schluss.
make[1]: Verzeichnis „/home/mborreguero/Work/lammps-11Aug17/src/Obj_mpi“ wird verlassen
Makefile:158: die Regel für Ziel „mpi“ scheiterte
make: *** [mpi] Fehler 2
Could some one maybe help me?
Thank you in advance,
Morgane
Dear Lammps user,
ERROR: Invalid dump style (../output.cpp:574)
also I did :
make yes-USER-VTK
make mpi
And also when I do "make yes-USER-VTK" it works, but the next command line
give me:
wird betreten
../../lib/quip/Makefile.lammps:17: *** Environment or make variable
QUIP_ROOT must be set.. Schluss.
wird verlassen
wird betreten
wird verlassen
this has *nothing* to do with USER-VTK, but an incorrect installation of
the USER-QUIP package.
you need to read the "Getting started" section in the LAMMPS manual more
carefully. it is all explained there in great detail.
Dear Alex,
ok I will focus on QUIP. Thank you
Morgane
