Hello LAMMPS community,
I am trying to create a system of equilibrated non-flexible SPC/E water with an embedded EAM Au nanoparticle. The Au-O interaction is described by 6-12 LJ. My question is how to properly handle bonds and special bonds. LAMMPS warning message says: “The exclusion settings will eliminate neighbors in the neighbor list, which the many-body potential needs to calculate its terms correctly.” Do I understand it correctly that the O and H atoms that have bonds between them are not interacting with Au atoms in my setup?
The part of my script where I set up simulation:
pair_style lj/cut/coul/long 9.0 9.0
special_bonds lj/coul 0.0 0.0 0.5
bond_style harmonic
angle_style harmonic
dihedral_style none
improper_style none
read_data water_20nm.dat extra/atom/types 1
##########__Technical part where I create the nanoparticle__####
region to_del_inner sphere ${x_cent} ${y_cent} ${z_cent} ${R_Au_del} side in units box
region to_create_Au sphere ${x_cent} ${y_cent} ${z_cent} ${R_Au} side in units box
delete_atoms region to_del_inner mol yes
lattice fcc 4.1464
create_atoms 3 region to_create_Au
mass 3 196.966569
########__The part is over__#############
pair_style hybrid eam/alloy lj/cut/coul/long 9.0 lj/cut 9.0
pair_coeff * * eam/alloy Au-W1266.v1.eam.alloy NULL NULL Au #Au - Au
pair_coeff 1 1 lj/cut/coul/long 0.15539421659476232 3.16555789 #O-O
pair_coeff 1 2 lj/cut 0.0000 0.0000 # O-H
pair_coeff 2 2 lj/cut 0.0000 0.0000 #H-H
pair_coeff 2 3 lj/cut ${epsHAu} ${sigmaHAu}# Au-H
pair_coeff 1 3 lj/cut ${epsOAu} ${sigmaOAu}# Au-O
pair_modify tail yes
kspace_style pppm 1.0e-4
bond_coeff 1 5000.00 1.000
angle_coeff 1 500.0 109.47
reset_ids
neighbor 2.0 bin
neigh_modify every 1 delay 10 check yes
Thank you!
