elastic constants script
Hi everybody
I spend my time trying to find the way to calculate the elastic constants using lammps. Right now i am using this script but it is not giving good results so would you like please to check it and if you find something wrong correct it. At least in the future, other users can use the code ready.
thanks
################## variable definition
You can upload this to the user-contributed section
of the WWW site if you like. There is an elastic constant
script provided with LAMMPS in the examples dir.
Steve the code for elastic constant is for 0K temperature. The code that I wanted you to check is for a finite temperature T. Did you check my code if it is correct or not because somehow it is giving me bad results?
no - I don't have time to check people's scripts.
