Electric_field
Dear lammps users,
I’m using lammps/reax/c for simulating decomposition of an organic compound under a constant electric field. From outputs (I mean dump.xyz and specie) I recognized that the electric field is worked but I’m not sure that it’s exactly correct or not. Please look into my input file and make recommends if it needs. This is my input file:
echo both
units real
atom_style charge
read_data NBCom.data
#read_restart restart22
restart 500 restart11 restart22
pair_style reax/c NULL
pair_coeff * * ffield.reax.rdx C H O N
compute reax all pair reax/c
variable eb equal c_reax[1]
variable ea equal c_reax[2]
variable et equal c_reax[9]
variable ew equal c_reax[11]
variable efi equal c_reax[13]
variable eqeq equal c_reax[14]
#define a region for efield
region elecf block 0.0 100.0 0.0 100.0 0.0 100.0 units box
group elf region elecf
neighbor 2 bin
neigh_modify every 10 delay 0 check no
velocity all create 300 235485 mom yes rot yes
fix 1 all nvt temp 300 300 25 ###########timestep*100=25
fix 2 all qeq/reax 1 0.0 10.0 1e-6 reax/c
fix 3 all reax/c/species 1 50 250 species.txt
fix 4 elf efield 2.0 0.0 0.0 region elecf
fix_modify 4 energy yes
thermo_style custom step atoms temp press vol etotal ke pe v_eb v_ea v_et v_ew v_efi v_eqeq
thermo 250
timestep 0.25
dump 1 all atom 30 dump.reax.rdx
dump 2 all xyz 30 dumpnvt.xyz
run 30000
Thanks in advance
Mohammad Ebrahim Izadi
Dear lammps users,
​you seem to be confusing the purpose of a mailing list. it is most
certainly not an input file approval or debugging/correction service​.
in other words, it is part of the job of a researcher to validate that a
chosen model is giving results at the expected level of accuracy and
usefulness.
please let me repeat what i have pointed out in an earlier e-mail response.
when you are using fix efield, you are not exactly applying an electric
field, you are adding a force to all charged atoms, that depends on the
product of the (partial) charge of each atom and a given force constant
with conversion factor.
this does not include the electric field in the charge equilibration (only
indirectly over response to the force generated by fix efield) and there is
no screening or other effects taken under consideration.
​axel.​
