hello all,
I have a question, i want to convert the charge in metal units to electrostatic charge or electrostatic voltage. how to do this?
hello all,
hello all,
your question doesn't make much sense. what is the difference between
"charge" and "electrostatic charge". as explained in a previous
e-mail. the unit of charge in metal units is the charge of one
electron. voltage, on the other hand, is potential energy *per*
charge, so you cannot convert from charge to energy per charge. that
doesn't match.
since there is no context whatsorever given here, it is practically
impossible to give a meaningful answer beyond what what mentioned
above. you have to learn to describe accurately and precisely what you
are computing (and from the looks of it, you may need to spend some
time with a text book on the fundamentals, too.).
