Is it possible to compute on the fly the average (over molecules and time) of the end-to-end distance of a molecule given that the terminal atoms have a distinguishing type? I started trying to use a compute property/molecule command but I don’t seem to be able to take advantage of it.
I guess another way of doing it would be computing the distance between two atoms of terminal type if they belong to the same molecule.
Thanks for suggestions.
command but I don't seem to be able to take advantage of it.
do you need this information during the simulation?
it would be extremely easy to do this kind of analysis in post-processing.
I would like very much to be able to time average, hence take
advantage of a fix ave/time command. This is why I am trying to get
the information on the fly. Otherwise, yes, an off-line calculation
can be done easily but on lots of configuration files.
Have a look at compute gyration and gyration/molecule.
I imagine they could be modified to calculate what you want.
Thanks; will consider. I was looking at extending
would this be a more generic alternative?
One additional question. In thinking about whether extend/modify code
or create new code for lammps, I have the impression that lammps
"fixes" are actually "computes" and "computes" are actually
"definitions." Is this another way to look at them?
Comments below.
No - I think you are better off with a new compute.
If you are asking an English language question, I don't think
it matters what you call them. They are what they are. I would
read the fix.html and compute.html doc pages to get a sense of what
they do in a LAMMPS context.
