Hi, I’m trying to calculate the e_above_hull of entry (mp-771246). I can find that the e_above_hull is 0.045 eV/atom from the materials website. However, when i try to use the following code to calculate the e_above_hull, it gives 0.015 eV/atom. So I’m wonder which is resonable value ?
from pymatgen.core import Element
from pymatgen.analysis.phase_diagram import PhaseDiagram
from pymatgen.ext.matproj import MPRester
from itertools import combinations
from monty.serialization import loadfn,dumpfn
import os
mpr=MPRester("-----------------")
mid="mp-771246"
if os.path.exists('entries.json'):
entries=loadfn('entries.json')
else:
dentries={}
elms=['Li',"V","Te","O"]
for i in range(1,len(elms)+1):
for comb in combinations(elms,i):
if len(comb)==1:
key=comb[0]
dentries[key]=mpr.get_entries(key)
else:
key='-'.join(list(comb))
print(key,len(dentries[key]))
entries=[]
for key in dentries.keys():
entries.extend(dentries[key])
dumpfn(entries,'entries.json',indent=4)
te=entries[-1] # this one is mp-771246
print(te)
pd=PhaseDiagram(entries=entries)
dumpfn(pd.as_dict(),'pd.json',indent=4)
print(pd.get_e_above_hull(te))
output:
mp-771246 ComputedEntry - Li2 V3 Te1 O8 (Li2V3TeO8)
Energy (Uncorrected) = -94.9128 eV (-6.7795 eV/atom)
Correction = -11.0180 eV (-0.7870 eV/atom)
Energy (Final) = -105.9308 eV (-7.5665 eV/atom)
Energy Adjustments:
MP2020 anion correction (oxide): -5.4960 eV (-0.3926 eV/atom)
MP2020 anion correction (Te): -0.4220 eV (-0.0301 eV/atom)
MP2020 GGA/GGA+U mixing correction (V): -5.1000 eV (-0.3643 eV/atom)
Parameters:
run_type = GGA+U
is_hubbard = True
pseudo_potential = {'functional': 'PBE', 'labels': ['Li_sv', 'V_pv', 'Te', 'O'], 'pot_type': 'paw'}
hubbards = {'Li': 0.0, 'V': 3.25, 'Te': 0.0, 'O': 0.0}
potcar_symbols = ['PBE Li_sv', 'PBE V_pv', 'PBE Te', 'PBE O']
oxide_type = oxide
Data:
oxide_type = oxide
oxidation_states = {'Li': 1.0, 'V': 5.0, 'Te': -1.0, 'O': -2.0}
0.01495586022919504
