lammps developers,
I’m using lammps to generate 10 data points (potential energy, coordinates) for a diamond uniaxial tension case to compare to experimental work. I’ve attached a small sample script.
I noticed that the fix deform command operates on the atoms after the energy/forces are calculated but before the coordinates are dumped. This leads to identical energies for timestep 0 and 1, but updated coordinates in the dump file for timestep 0 and 1. After timestep 0 the potential energies lag behind by 1 timestep.
I see in the manual under fixes that “fixes perform their operations at different stages of the timestep.” Although I didn’t notice anything in the deform manual that indicated when or why it’s invoked where it is in a timestep.
Normally it’s never made a big difference, however in this special situation invoking the deform fix where it currently is in the timestep was unintuitive and took me a while to track down the error. Is there a reason for the deform fix to be invoked where it is now, or is this a bug?
Using rerun on the coordinates generated with the attached script and the dump file it generates gives matching energy/coordinates.
Thanks.
-Ben
Benjamin D. Jensen
PhD Candidate
Department of Mechanical Engineering - Engineering Mechanics
Michigan Technological University
Houghton, MI
in.script (816 Bytes)
