Hi lammps users,
I am trying to implement a new pair potential, and so I am going through
the source code, in particular pair_lj_cut.cpp, pair_tersoff.cpp, and
pair.cpp.
What does eflag and vflag refer to? Also, how is energy summed (i.e. which
variable)?
Thanks for your help
John
Hi lammps users,
pair.cpp.
you should also have a look at verlet.cpp.
variable)?
eflag is true if energies are to be evaluated, vflag if the virial is required.
using the calls to ev_tally*().
Thanks for the help!
I have another question about the Tersoff.cpp implementation. What is the
attractive() subroutine for? It is called after the energies for Fr(ij)
and b(ij)*Fa(ij) are summed with ev_tally(). It looks like a virial
component but I don't understand how it is applied.
Thanks again,
John
that is part of the 3-body term. i don't know the tersoff implementation
that well, but the virial component is tallied later using v_tally3()
you'll have to read the sources and compare to the documentation
and probably also the reference papers for the tersoff potential...
