energy in the comb potential
Hello,energyone. I am using the pair_style comb for si and oxygen mixed system. But the energy is not strictly conserved at NVE ensemble. I don’t know why.
#relax file
atom_style full
read_data data
timestep 0.00001
pair_style comb
pair_coeff * * …/…/…/source/lammps-7May11/potentials/ffield.comb Si O
neighbor 2.0 bin
neigh_modify every 100 delay 0 check no
group si type 1
group o type 2
compute mke all ke/atom
compute mytemp all temp
compute mypress all pressure mytemp
compute mycoord all coord/atom 2.0
compute myrdf all rdf 300 1 2 2 1 1 1 2 2
fix my_charge all qeq/comb 100 1e-4 file charge.txt
fix 40 all ave/time 100 10 1000 c_myrdf file rdf.txt mode vector
fix 10 all nve
dump 1 all custom 100 dumpminimize.lammpstrj id type x y z vx vy vz c_mke c_mycoord
thermo_style custom step temp press pe ke etotal vol
thermo 100
thermo_modify lost warn
run 10000
Step Temp Press PotEng KinEng TotEng Volume
0 0 -30409.89 -8764.4647 0 -8764.4647 16710.449
100 3.2920439 -2831.3398 -9304.8349 0.57404007 -9304.2608 16710.449
200 8.8541363 -2753.4998 -9309.0456 1.5439129 -9307.5016 16710.449
300 17.064685 -2545.0014 -9310.7304 2.9756022 -9307.7548 16710.449
400 27.387098 -2589.5092 -9312.5881 4.7755414 -9307.8125 16710.449
500 39.206384 -2627.8077 -9314.737 6.836493 -9307.9005 16710.449
600 51.649505 -2656.7188 -9316.9205 9.0062242 -9307.9143 16710.449
700 64.062509 -2646.631 -9319.1331 11.170704 -9307.9624 16710.449
800 75.667136 -2606.8826 -9321.2449 13.194225 -9308.0506 16710.449
900 86.057877 -2514.7086 -9323.2116 15.006079 -9308.2055 16710.449
1000 94.787753 -2375.2974 -9324.6174 16.528324 -9308.0891 16710.449
1100 101.84296 -2153.8201 -9325.5275 17.758554 -9307.769 16710.449
1200 107.25102 -1906.3511 -9326.2126 18.701567 -9307.511 16710.449
1300 111.30853 -1665.2967 -9327.0939 19.409083 -9307.6848 16710.449
1400 114.50616 -1358.6667 -9327.0218 19.966661 -9307.0551 16710.449
1500 117.2052 -1052.1957 -9327.9975 20.437297 -9307.5602 16710.449
1600 120.43893 -488.41558 -9326.3032 21.001169 -9305.302 16710.449
1700 123.91806 -266.29832 -9328.6763 21.607832 -9307.0685 16710.449
1800 129.56759 419.06134 -9324.8052 22.592952 -9302.2123 16710.449
1900 135.66539 329.10572 -9329.7954 23.656237 -9306.1392 16710.449
2000 144.97429 820.37329 -9327.2936 25.279448 -9302.0142 16710.449
2100 154.63009 454.01447 -9333.0036 26.963148 -9306.0404 16710.449
2200 167.60253 651.50696 -9331.3669 29.225178 -9302.1417 16710.449
2300 180.1725 -74.435672 -9337.4451 31.417028 -9306.0281 16710.449
2400 195.49719 -279.93928 -9336.3616 34.089223 -9302.2723 16710.449
2500 209.25474 -1495.323 -9342.46 36.488153 -9305.9719 16710.449
2600 224.81402 -2259.2859 -9341.6736 39.201257 -9302.4724 16710.449
2700 237.57008 -4047.0341 -9347.3957 41.425554 -9305.9701 16710.449
2800 251.17445 -5325.7463 -9346.4827 43.797775 -9302.6849 16710.449
2900 261.09225 -7680.4216 -9351.4766 45.527162 -9305.9494 16710.449
3000 271.33599 -9288.4943 -9350.2005 47.313383 -9302.8871 16710.449
3100 277.78931 -11814.892 -9354.3692 48.438659 -9305.9306 16710.449
3200 284.52544 -13702.786 -9352.6776 49.613252 -9303.0643 16710.449
3300 287.64537 -16415.933 -9356.0656 50.15728 -9305.9083 16710.449
3400 291.28056 -18403.735 -9354.0117 50.791155 -9303.2205 16710.449
3500 291.7951 -21264.05 -9356.6685 50.880876 -9305.7877 16710.449
Regards,
Lisa
system. But the energy is not strictly conserved at NVE ensemble. I don't
know why.
lisa,
your system is not equilibrated. note how the temperature is
rising. that will change the average potential energy for any
interaction model with a cutoff.
cheers,
Yes, the system is a perfect crysal structure and it is not equilibrated. It is normal that the potential energy
changes, but it is strange that the total energy also change, right?
Lisa
2011/7/30 Axel Kohlmeyer <[email protected]>
no, it is not strange.
The energy still not conserved under NVE ensemble after relax the sample.
Reading restart file …
orthogonal box = (0.112875 0.265733 -0.178695) to (24.7611 23.9103 26.5607)
1 by 1 by 1 processor grid
1350 atoms
Finding 1-2 1-3 1-4 neighbors …
0 = max # of 1-2 neighbors
0 = max # of 1-3 neighbors
0 = max # of 1-4 neighbors
1 = max # of special neighbors
Pair COMB:
generating Coulomb integral lookup table …
will not apply over-coordination correction …
450 atoms in group si
900 atoms in group o
Setting up run …
Memory usage per processor = 13.2162 Mbytes
40030 299.50632 -3399.0848 -9380.0501 52.225496 -9327.8246 15583.62
40100 301.40278 -3627.9597 -9380.3944 52.556187 -9327.8382 15583.62
40200 299.49369 -3058.3614 -9380.4338 52.223294 -9328.2105 15583.62
40300 297.73704 -3008.8485 -9380.3931 51.916985 -9328.4761 15583.62
40400 298.4974 -3815.1401 -9380.7934 52.04957 -9328.7438 15583.62
40500 296.93445 -2871.7237 -9380.6623 51.777034 -9328.8852 15583.62
40600 296.22056 -2385.6761 -9380.6744 51.652553 -9329.0218 15583.62
40700 295.5413 -2485.1103 -9380.7871 51.534109 -9329.253 15583.62
40800 294.40453 -2800.4769 -9380.757 51.335887 -9329.4211 15583.62
40900 294.91109 -4029.2684 -9380.9951 51.424217 -9329.5709 15583.62
41000 294.8136 -4550.1485 -9381.1722 51.407218 -9329.7649 15583.62
41100 294.52002 -4692.1473 -9381.294 51.356026 -9329.938 15583.62
41200 293.74085 -4299.1427 -9381.3302 51.220161 -9330.11 15583.62
41300 292.84458 -4166.7008 -9381.3051 51.063876 -9330.2412 15583.62
41400 291.9875 -3818.1368 -9381.288 50.914425 -9330.3736 15583.62
41500 292.22486 -4139.7661 -9381.3909 50.955814 -9330.4351 15583.62
41600 291.44179 -4357.3229 -9381.3123 50.819268 -9330.4931 15583.62
41700 292.04081 -5231.8378 -9381.5747 50.923721 -9330.651 15583.62
41800 291.30429 -4315.847 -9381.6166 50.795293 -9330.8213 15583.62
41900 291.43694 -3820.0453 -9381.8236 50.818423 -9331.0052 15583.62
42000 291.54592 -3465.1579 -9382.0039 50.837427 -9331.1665 15583.62
42100 291.18235 -3581.6862 -9382.0957 50.77403 -9331.3217 15583.62
42200 290.8084 -4693.1224 -9382.078 50.708823 -9331.3692 15583.62
42300 290.46741 -5741.197 -9382.1064 50.649364 -9331.457 15583.62
42400 289.90072 -6021.0294 -9382.0765 50.55055 -9331.5259 15583.62
42500 289.74831 -5817.0606 -9382.2663 50.523973 -9331.7423 15583.62
42600 289.0337 -4688.3145 -9382.2746 50.399366 -9331.8752 15583.62
42700 288.82344 -4578.9096 -9382.3418 50.362702 -9331.9791 15583.62
42800 288.13419 -5038.9561 -9382.2868 50.242516 -9332.0443 15583.62
42900 287.66444 -5893.5646 -9382.2405 50.160605 -9332.0799 15583.62
43000 287.69965 -5804.7759 -9382.2847 50.166745 -9332.118 15583.62
43100 287.53874 -4900.548 -9382.3959 50.138687 -9332.2572 15583.62
43200 287.22545 -4039.2704 -9382.5019 50.084058 -9332.4178 15583.62
43300 287.62307 -4079.8858 -9382.7013 50.153391 -9332.5479 15583.62
43400 287.34961 -4954.6279 -9382.7308 50.105708 -9332.6251 15583.62
43500 287.25614 -6208.2754 -9382.7393 50.089409 -9332.6499 15583.62
43600 286.82393 -6446.6266 -9382.7605 50.014044 -9332.7464 15583.62
43700 286.65502 -6880.4882 -9382.8722 49.984592 -9332.8876 15583.62
43800 286.19159 -6486.8399 -9382.8148 49.903782 -9332.9111 15583.62
43900 285.58009 -5994.9374 -9382.8162 49.797153 -9333.0191 15583.62
44000 284.92103 -5880.9965 -9382.7376 49.682232 -9333.0554 15583.62
44100 284.77501 -6123.1108 -9382.6799 49.656771 -9333.0232 15583.62
44200 284.47699 -6025.0264 -9382.773 49.604803 -9333.1682 15583.62
44300 284.78004 -5654.9529 -9382.9334 49.657646 -9333.2757 15583.62
44400 284.34099 -4908.5595 -9383.0142 49.581089 -9333.4331 15583.62
44500 284.43275 -4750.5852 -9383.0428 49.59709 -9333.4457 15583.62
44600 284.5622 -5307.7774 -9383.1382 49.619661 -9333.5186 15583.62
44700 283.92551 -6206.3685 -9383.0019 49.508641 -9333.4933 15583.62
44800 283.94064 -6840.4254 -9383.0952 49.51128 -9333.5839 15583.62
44900 283.46357 -7082.4866 -9383.0817 49.428092 -9333.6536 15583.62
45000 283.42072 -7100.1237 -9383.1389 49.420619 -9333.7182 15583.62
45100 283.61109 -6785.3698 -9383.2587 49.453814 -9333.8049 15583.62
45200 283.22409 -6238.2096 -9383.2362 49.386333 -9333.8499 15583.62
45300 283.10302 -6235.7409 -9383.1356 49.365222 -9333.7703 15583.62
45400 283.44208 -6335.29 -9383.3281 49.424344 -9333.9038 15583.62
45500 283.19765 -6543.2803 -9383.2491 49.381722 -9333.8673 15583.62
45600 283.08831 -6186.3419 -9383.3248 49.362657 -9333.9621 15583.62
45700 282.81775 -6000.5188 -9383.4641 49.315478 -9334.1487 15583.62
Lisa
your kinetic energy is decreasing, so you are not in equilibrium.
Send an email to the COMB author (Ray Shan, see the
top of src/pair_comb.cpp for his email) with your script
and see if he has any concerns - e.g. if
your timestep is too big.
