Energy is not equal to zero at a distance large then Rcut
According to the rule, if the atomic distance is greater than the Rcut, there is no interaction.
But I found that the interaction was not completely eliminated at a distance greater than Rcut
Take bilayer graphene as example: initial layer distance=3.4A, Rcut=2A, 9000 atoms
The potential function is set as follows:
pair_style hybrid/overlay lj/cut 2
pair_coeff * * none
pair_coeff 1 2 lj/cut 1.0 1.4
by " run 0 ", the interlayer energy is calculated to be ~0.5eV. Then I reduce the Rcut and the energy stays the same.
Is that normal? I think the energy should always be zero in this case
There is not enough information here to make any statement. Your choice of parameters seems odd for using metal units and it is not clear whether there are interactions due to periodic boundary conditions.
Axel
I want to verify the relationship between the interaction and the Rcut
The actual parameters are not like this
The box is large enough that the atoms occupy only part of its center
atom_style bond
neighbor 3.0 bin
read_data 0.data
pair_style hybrid/overlay lj/cut 0.4
pair_coeff * * none
pair_coeff 1 2 lj/cut 1.0 2.5
mass 1 12.01
mass 2 12.01
timestep 0.001
neigh_modify every 5 delay 0 check yes one 10000
velocity all create 1 1233511
thermo 1
thermo_style custom time etotal
run 0
在 2019-03-04 21:23:25,“sumiya” <[email protected]…5094…> 写道:
The actual parameters are not like this.
atom_style bond
neighbor 3.0 bin
read_data 0.data
pair_coeff * * none
mass 1 12.01
mass 2 12.01
timestep 0.001
thermo 1
run 0
在 2019-03-04 21:58:05,“Axel Kohlmeyer” <[email protected]…24…> 写道:
Why should the total energy be zero, when you assign a kinetic energy?
Oh, I see. I made a stupid mistake. Thank you again
