energy minimization
Hi lammps users,
I came across a very simple problem when doing energy minimization, this is my input script:
variable etol equal 0.0
variable ftol equal 1.0e-10
variable maxiter equal 10000
variable maxeval equal 10000
variable dmax equal 1.0e-2
atom_style atomic
#lattice fcc 3.61 orient x -1 0 1 orient y 1 -2 1 orient z 1 1 1
lattice fcc 3.61 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region myreg block 0 2 0 2 -2 2
create_box 1 myreg
create_atoms 1 box
pair_style eam
pair_coeff * * Cu_u3.eam
neighbor 3.0 bin
min_style cg
dump 1 all custom 10 dump.minimize id type x y z
minimize {etol} {ftol} {maxiter} {maxeval}
when the axis orientation is “x 1 0 0 y 0 1 0 z 0 0 1”, there are no differentce between the initial atomic structure and the one after energy minimization. But when the axis orientation is “x -1 0 1 y 1 -2 1 z 1 1 1”the initial atomic structure will change after energy minimization, and I feel this is rather weird. I have tried other axis orientation “x 1 1 1 y 1 -1 0 z 1 1 -2” and other potential, or change the material from Cu to Ni, but the results are same: the initial structure except for “x -1 0 1 y 0 1 0 z 0 0 1” will change.
Any help will be appreciated.
All the best.
Lily
Hi lammps users,
my input script:
i don't feel that this is weird at all. this is basic crystal
structure knowledge.
you have chosen an orientation, where you need to have a simulation
cell length in y-direction that needs to be a multiple of 3 of the
lattice spacing in order to have a perfect continuation across
periodic boundaries.
change your box to:
region myreg block 0 2 0 3 -2 2
and you will see.
