Equilibration of core/shell using both Berendsen thermostat and Nose-Hoover barostat
Dear LAMMPS users,
As suggested in the manual the equilibration of core/shell should be done using a thermostat. e.g. Berendsen
Can the equilibration be done using both Berendsen thermostat and Nose-Hoover Barostat so the box relaxation can also be done simultaneously ?
I have tried to do that. The input script is given below. Please suggest me whether this is correct procedure or any modification has to done.
#------------------------INITIALIZATION----------------------------
atom_style full
#-----------------------ATOM DEFINITION----------------------------
#fix csinfo all property/atom i_CSID
read_data inp.xyz # fix csinfo NULL CS-Info
group cores type 1 2 3
group shells type 4 5 6
neighbor 2.0 bin
comm_modify vel yes
------------------------FORCE FIELDS------------------------------
kspace_style ewald 1.0e-6
pair_style buck/coul/long/cs 11.0 # A, rho, sigma=0, C, D
pair_coeff * * 0.0 1.0 0.0
pair_coeff 4 6 1545.21 0.3590 0.0 #La-O
pair_coeff 5 6 1267.50 0.3214 0.0 #Sr-O
pair_coeff 6 6 22764.3 0.1490 43.0 #O-O
bond_style harmonic
bond_coeff 1 145.0 0.0
bond_coeff 2 95.0 0.0
bond_coeff 3 42.0 0.0
------------------------ Equilibration Run -------------------------------
reset_timestep 0
thermo 100
thermo_style custom step temp pe etotal press vol cella cellb cellc cellalpha cellbeta cellgamma
compute CSequ all temp/cs cores shells
compute CSpress all pressure CSequ
thermo_modify temp CSequ
velocity bias option
velocity all create 1427 134 dist gaussian mom yes rot no bias yes temp CSequ
velocity all scale 1427 temp CSequ
fix thermoberendsen all temp/berendsen 1427 1427 0.4
fix NPH all nph iso 0.0 0.0 1.0
fix_modify thermoberendsen temp CSequ
fix_modify NPH press CSpress
1 fmsec timestep
timestep 0.001
run 100000
unfix thermoberendsen
unfix NPH
fix nve all nve
------------------------ Dynamic Run -------------------------------
dump 1 all custom 100 Trajectory id xu yu zu vx vy vz
run 100000
Regards
Omkar
I don’t see any problem in principle with using
fix nph as a barostat in conjunction with the core shell
model and its thermostat. If no on else answers on the mail list,
I suggest you send an email to the author of
the CORESHELL package. His contact info
is in the src files or package documentation.
Thank You very much Steve for Your suggestion. I will do accordingly.
Regards
Omkar
