Dear Lammps users,
I have been running into this problem for long time now, whenever the equilibration starts the beam starts shaking. When I use the same code for Aluminum it works fine. Any suggestions are welcom. Thanks
------------------------ INITIALIZATION ----------------------------
echo screen
atom_style atomic
----------------------- ATOM DEFINITION ----------------------------
variable latparam equal 5.431
variable nL_x equal -65.431
variable L_x equal 65.431
#x= nm
variable nL_y equal -95.431
variable L_y equal 95.431
y= nm
variable nL_z equal -85.431
variable L_z equal 85.431
z= nm
variable L_fixed equal (-5.55.431)
variable L_mobile equal (5.55.431)
lattice diamond {latparam}
region beam block {nL_x} {L_x} {nL_y} {L_y} {nL_z} ${L_z} units box
region whole block -100 100 -100 100 -100 100 units box
create_box 1 whole
lattice diamond ${latparam} orient x 1 1 0 orient y 0 0 1 orient z 1 -1 0
create_atoms 1 region beam
variable n equal count(all)
------------------------ FORCE FIELDS ------------------------------
pair_style meam
pair_coeff * * /usr/local/lammps-9Dec14/potentials/library.meam Si /usr/local/lammps-9Dec14/potentials/Ni.meam Si
neighbor 2.0 bin
neigh_modify delay 0 every 2 check yes
---------------------------Minimization-------------------------
#minimize etol ftol maxiter maxeval
Conjugate gradient Algorithm
min_style cg
minimize 1.0e-7 1.0e-7 100000 100000
variable tmp equal “lx”
variable L0 equal {tmp}
print "Initial Length, L0: {L0}"
------------------------------Equilibration---------------------
reset_timestep 0
timestep 0.001
velocity all create 300 12345 mom yes rot no
fix 2 all nvt temp 300.0 300.0 1.0
Set thermo output
thermo 1000
thermo_style custom step lx ly lz press pxx pyy pzz pe ke etotal temp
dump 1 all atom 100 dump.eq.lammpstrj
write_restart Compress.equil
Run for at least 10 picosecond (assuming 1 fs timestep)
run 20000
undump 1
unfix 2
variable L0 equal ${tmp}
variable LZ equal “lz”
