Dear Lammps users,
In the webpage
http://sourceforge.net/p/lammps/mailman/message/31607022/
it is mentioned that:
the only way to confirm this,is to run *without* a thermostat.
energy has to be conserved by that,and if you start of an optimal
structure the equilibrium kinetic energy should be *half* of what
you initially assign.
and that:
try running with fix nve and without *any* thermostat, just the
initial temperature assignment.if your system is properly relaxed
and minimized the final temperature should be about half the initial
value.
I need some explanation.
Thanks for the help,
Erchia
Dear Lammps users,
In the webpage
the only way to confirm this,is to run without a thermostat.
structure the equilibrium kinetic energy should be half of what
and that:
try running with fix nve and without any thermostat, just the
value.
Please pick up a decent textbook about MD and read about equilibration and how kinetic energy is converted into potential energy in the process (or vice versa).
Axel
