Hello all,
I want to create a composite structure using amorphous silica and crystalline silicon using a long-range user-defined potential and Stillinger-Weber potential, respectively.
I initially made silica glass, and the simulation box is augmented to insert crystalline silicon atoms in the box, using periodic boundary conditions. The structure looks pretty good until I start a minimization run. During minimization, I find that the pressure shoots up unrealistically high, so does the potential energy. This may be because the atoms are close enough at the interface. Having that said, deletion of the overlapping atoms did not help either. Before I start to run any MD algorithm, I find that the crystallinity of the silicon atoms is lost. In this regard, I have the following concerns.
- While the constituents of silica have charged particles that will later interact with neutral silicon atoms, how does that interaction work? I mean, is it okay to run the entire simulation using the atom_style charge?
- Are such chaos prevalent while using the hybrid style? How would you think that I can improve the system to proceed further? As you will be able to make out now, my main aim is to generate an equilibrated composite structure with x-silicon and a-silica structures using PBC.
Any guidance would be highly appreciated.
Thank you so much for your attention and participation.
Kiran
