I tried with more number of mpi ranks, ie with following run command:
"aprun -n 2 -N 2 …/…/lmp_intel_coprocessor_14.0 -pk intel 1 -sf intel -in in.intel.rhodo "
with MIC_OMP_NUM_THREADS=2
got following error:
^Moffload error: cannot find data associated with pointer variable 0x2aaab559e3c0
^Moffload error: cannot find data associated with pointer variable 0x2aaabdae53c0
with -n=6 -N=6 (rest same)
^Moffload error: cannot find data associated with pointer variable 0x2aaab43f8e40
^Moffload error: cannot find data associated with pointer variable 0x2aaab5660ec0
^Moffload error: cannot find data associated with pointer variable 0x2aaab5676ec0
^Moffload error: cannot find data associated with pointer variable 0x2aaabb3e2e80
^Moffload error: cannot find data associated with pointer variable 0x2aaab43f8f40
we have Allinea DDT, which says on website that it supports Intel phi as well, will see if it turns out anything (that is if we have latest version which supports xeon phi). Also will try to compile with latest compiler version as soon as possible (will take some time though).
Thank you
