I’m trying to compile the shared library mpi build of LAMMPS and I’m getting an error for the target lmp_mpi where there is an undefined reference to “LAMMPS_NS::MLIAPModelPython::connect_param_counts()” in liblammps_mpi.so.
Compiling that static library works just fine. I don’t know if there is an issue with my setup or why they would differ here. I have tried this with both python 2 as a system package and python 3.10 in a virtual env, although I can’t image the python version is the culprit here. This has been in a docker container based on ubuntu:18.04, but I am also encountering the issue outside docker. I’ve also tried the latest stable commit (https://github.com/lammps/lammps/tree/7586adbb6a61254125992709ef2fda9134cfca6c) and an older stable tag (stable_3Mar2020).
I’m mostly just wondering if there is an obvious difference between the static and shared library build process that I was supposed to be aware of or if there is perhaps a bug I should report. I can share my current Dockerfile and a build output if that would be helpful.
Scott
