Hello, lammps-users,
I use the command compute msd to compute the self-diffusion of methane. The error ‘Compute used in variable between runs is not current’ was triggered. The manual doc gives the method, add ‘run 0’ before the variable refering compute. And I write my input as the example in.msd.2d. But the error is still there. The commad line which trigger the error is attached below. Anyone can help me? Thanks in advance.
variable temp equal 333
fix metnvt methane nvt temp {temp} {temp} 100
thermo_style custom step time temp press pe ke etotal
thermo 1000
run 2000
reset_timestep 0
compute msd1 layer1 msd com no average no
compute msd2 layer2 msd com no average no
compute msd3 layer3 msd com no average no
compute msd4 layer4 msd com no average no
#variable dxdx1 equal c_msd1[1]
#variable dydy1 equal c_msd1[2]
#variable dzdz1 equal c_msd1[3]
variable dxdxdydy1 equal $(c_msd1[1]+c_msd1[2])
variable dxdx2 equal c_msd2[1]
variable dydy2 equal c_msd2[2]
variable dzdz2 equal c_msd2[3]
Best regard
Dongbo Wang
