Greetings,
I have looked at a similar error posted on the mailing list archives, however the solution doesn’t seem applicable in my case. I am equilibrating a box of about 1000 beads in the NPT ensemble and the styles and parameters have been chosen based on polymerization I plan to do post equilibration.
However, this error presents itself when reading the Dihedral Coeffs (fourier) part of the data file. I am attaching the files for your references as well as listing the script below:
-------------------------------LAMMPS File------------------------
units real
atom_style full
pair_style lj/cut 15.0
bond_style class2
angle_style class2
dihedral_style fourier
neighbor 5.0 bin
neigh_modify delay 10
read_data pack_M.lmp
angle_coeff 1 99.8 8.25 0.320848 0.294303 #Class2 style = TEAM-MS style for #Ea term
angle_coeff 1 bb 0.0 0.0 0.0 #No BB term in force field TEAM-MS
angle_coeff 1 ba 0.0 0.0 0.0 0.0 #No BA term in force field TEAM-MS angle_coeff 2 99.8 10.03 0.24716 0.25374
angle_coeff 2 bb 0.0 0.0 0.0
angle_coeff 2 ba 0.0 0.0 0.0 0.0
compute 1 all temp/com
compute 2 all com
compute 3 all pressure 1
compute 4 all rdf 50 * * cutoff 25.0
minimize 1.0e-4 1.0e-6 1000 100000
fix 1 all langevin 300.0 300.0 150 12345
thermo 100
thermo_style custom step temp press etotal epair c_2 vol density
thermo_modify norm yes temp 1
run 5000
unfix 1
fix fxNPT all npt temp 300.0 300.0 500.0 iso 1.0 1.0 500.0
thermo 100
run 100000
write_data system_npt_relax.data
----------------------Data File------------------------
1015 atoms
0 bonds
0 angles
0 dihedrals
0 impropers
2 atom types
3 bond types
2 angle types
2 dihedral types
0 improper types
2 extra bond per atom
9 extra angle per atom
16 extra dihedral per atom
-2.500000 113.500000 xlo xhi
-2.500000 113.500000 ylo yhi
-2.500000 113.500000 zlo zhi
Masses
1 74.15294 # M
2 81.18766 #E
Atoms # full
##Not including coordinates as 1015 atoms will take too much space##
Pair Coeffs
1 1 0.533811 5.653 #14.1325
2 2 0.323278 5.613 #14.0325
Bond Coeffs #class2
1 3.500 30.5 -0.002151 0.00251
2 3.553 38.5 -0.001351 0.001584
3 3.553 38.5 -0.001351 0.001584
#Angle Coeffs #class2
Dihedral Coeffs #fourier
1 3 −0.2106 1 0.0 0.1689 2 180.0 0.1217 3 0.0
2 3 −0.2634 1 0.0 0.1872 2 180.0 0.117 3 0.0
Thanking you in advance for your help.
Your sincerely,
pack_M.lmp (54.4 KB)
NPT_min.in.lmp (2.89 KB)
