Hi lammps users,
what are the causes for this error?
ERROR: Expected integer parameter in input script or data file (…/group.cpp:313)
Hi lammps users,
Hi lammps users,
(../group.cpp:313)
exactly what the error message tells you. your input file has a
floating point number where there should be an integer. this looks as
if it is during a group command. run your input with -echo screen and
see at which line it terminates.
