dear lammps user,
i ve tried to run a job with the input script in.lj (which is in the bench directory) and gave the run command mpirun -np 2 lmp_g++ -v f tmp.out -l my.log -sc none <in.lj
the error showing is MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with error code 1.
However when i try run the job with in.micelle (in example/micelle/) then it is fine.
thanks,
atreyee
dear lammps user,
is fine.
there is no error here. since you are silencing the screen, what is
written in log.lammps?
