Error:Fix bond/create needs ghost atoms from further away
Hello,everyone
I used fix bond/create command to create new bond of C-N during Crosslinking procedure.
But i met a strange Error:
I can’t get it in the Manual and I really don’t know what does ghost atoms mean and what shall i do to modify this error.
could anyone give me some advices?
Thanks!
Kang
ErrorFix bond/create needs ghost atoms from further away
I can't get it in the Manual and I really don't know what does ghost
You need to increase the communication cutoff, so that atoms that would not be
included as ghost are transmitted across CPU boundaries
http://lammps.sandia.gov/doc/comm_modify.html
comm_modify cutoff XYZ
where XYZ is such that atoms one "possible bond" away will be present on a CPU.
If you use angular, dihedrals and impropers with fix bond create this will
effectively increase the value for XYZ.
Regards,
Pierre
