Dear all
As a beginner in LAMMPS, I’m using the NEMD method to calculate the thermal conductivity of single - layer graphene. I’ve used the “fix ehex” command, but I encountered the following error: “Fix ehex kinetic energy rescaling too large”. I haven’t found any solutions to this error on this forum or other websites. I hope someone can give me some guidance.
At the same time, when calculating the thermal conductivity with LAMMPS, I obtained the temperature gradient within a relatively small number of running steps and calculated the thermal conductivity through Fourier’s law. However, I clearly noticed that the value of the thermal conductivity is two orders of magnitude lower. Here is my in - file. I would be extremely grateful if you could give me some advice and suggestions on my in - file.
Kun
atom_style atomic
neighbor 0.3 bin
neigh_modify every 1 delay 10 check yes
variable T equal 300
variable A equal 1.42
variable DT equal 0.0002
variable POWER equal 0.005
lattice custom ${A} a1 3 0 0 a2 0 1.732 0 a3 0 0 2.357 &
basis 0 0 0 &
basis 0.333 0 0 &
basis 0.5 0.5 0 &
basis 0.833 0.5 0
region graphenesheet block 0 255.78 0 24.12 -0.5 0.5 units box
create_box 1 graphenesheet
create_atoms 1 region graphenesheet
mass 1 12.0107
change_box all z delta -150 150 units box
pair_style tersoff
pair_coeff * * SiC.tersoff C
write_data 1Model.data
timestep ${DT}
velocity all create ${T} 89684 dist gaussian
min_style cg
minimize 1e-10 1e-10 1000 1000
write_data 2min.data
dump 1 all custom 10000 4graphene.lammpsstrj id type x y z fx fy fz
fix NVT all nvt temp ${T} ${T} 0.02
thermo_style custom step temp press pe ke lx ly lz density
thermoss 100000
run 1000000
undump 1
write_data 3chiyu.data
unfix NVT
fix NVE all nve
run 100000
reset_timestep 0
region SOURCE block 0 1 INF INF INF INF units box
region SINK block 25 26 INF INF INF INF units box
fix HEAT_IN all ehex 1 ${POWER} region SOURCE
fix HEAT_OUT all ehex 1 -${POWER} region SINK
compute KE all ke/atom
variable KB equal 8.617e-5
variable TEMP atom c_KE/1.5/${KB}
compute BLOCKS all chunk/atom bin/1d x lower 0.02 units reduced
fix T_PROFILE all ave/chunk 10 10000 100000 BLOCKS v_TEMP file temp${T}.txt
thermo 100000
thermo_style custom step temp press lx ly vol
dump 1 all custom 100000 5conductivity.lammpsstrj id type x y z fx fy fz
run 5000000
NEMD.in (4.0 KB)
