error: fix vector and rerun
Dear Louis,
You did reset timestep by invoking the “rerun” command. From the manual: “Every time a snapshot is read, the timestep for the simulation is reset, as if the reset_timestep command were used.”
You could try using a loop with read_dump and run 0 commands.
Cheers,
Michal
